2 coats vs 3 coats of stucco
Ask the pros- November, 2001
Are there any advantages/disadvantages besides cost in using 2 coats (base and finish - 3/8") vs 3 coats (brown/scratch/finish-7/8") hard stucco.
  I have never done the thin coat stucco.
  There is a pre mixed portland product called
one coat stucco that is applied thin and  your scratch and brown can be done at the same  time. Although a portland cement finish
probably bonds fine, I have seen this done  with a synthetic finish. I have yet to see a  job done this way that doesn't look like the ocean, but I think that is mostly because it is applied
by inexperienced people, like EIFS workers.
One reason I doubt I'll ever do this is there isn't  enough room to straighten the wall to make up  for irregularities in the framing or blocks.
Even with 3/4" it is necessary to fill in thicker  or thinner to kill the bumps and waves in the  wall. It isn't unusual to find framing that is
1-1/2" or more out of true. Also, I don't  think you can beat a portland cement finish.
previous question
