Bonding stucco on parging
This is a masonry wall with a parge coat completed 3 years ago. It was painted with Behr masonry paint 1 year ago. We now are going to stucco. The contractor will use wire lath, but I read what you wrote and I want to give the stucco the best chance to succeed.
Do you think I got enough off ?
stucco on parge coat
Scraping most of the loose paint off is fine.
I am glad someone is using my chipping method. It is important to use a chemical bonder in the scratch coat to ensure a permanent bond.
Here it is again if you haven't seen the chipping and bonding method:
https://www.stucconews.net/questions/question2301.html
Here is a project where the parging was soft and we scored it:
stucco over parging
