Cracks
in squares
My friend in Los Angeles had stucco
put on
her home a month ago and now, when she stand back and look at the whole
house, it
is cracked in big uneven squares. The
contractor
says he does not see the pattern, although he does admit there are
cracks.
What
would cause the cracks to be in a
pattern??
This is caused by excessive shrinkage in
the finish
coat, for example too much lime
in the finish coat.
How do I know?
We were called to resurface a stucco
installation
that had the same grid of cracks
about 2 or 3 feet apart. It was obvious
there
was too much lime in the finish.
Excessive shrinkage can also be caused by
too
fine a sand, or working
in the sun in hot weather.
We recoated the cracked walls and there
isn't
a single crack today.
