A "reglet", or groove is cut into the brick
for the counter flashing. REGLETS DON"T WORK FOR STUCCO. |
Counter flashing is put
on and sealed to the vapor barrier with a flashing
sealer. |
The old finish coat
didn't bond to well to the basecoat. The wall was
recoated at some time with a spray on finish. |
We patched over the
flashing and recoated the walls with a new finish. The finish here is white portland cement and white sand. Red color was made by mixing red oxide paint color in the mortar. |
