Concrete
steps and patio doors Swami-Glad to see you
have reappeared. I've enjoyed your info
at stucconews.com for many years so much that
I've printed out all the info and saved it for
a reference. Here I've enclosed some
photos of the problem:
I need to repair stucco
around sliding glass door but it butts up
against the existing step down. There is
about a 1-1/2 gap between the wire and the
step now (probably the thickness of the stucco
+ mortar). Should I put a barrier between the
stucco repair and the remortar of the step?
Will I have to remove the whole step? (I
will, of course, be repairing the damaged
paper and wire lath.)
Hope you can advise.
Thank You.
