I have a new project where the stucco
installation foreman told my field QA inspector,
he has never heard of "pre-wetting CMU prior to
scratch coat."
We have always held the belief that SSD
(Wetting the blocks ) is the best state for CMU
during scratch coat application. However,
I have had a hard time pointing to a written
standard that agrees with my opinion of "best
practice."
We constantly badger installers to keep the
plaster moist for 3-days after texture to gain
optimum hydration but I've never had an
installer balk on pre-wetting.
Any good reference sources I could cite?
I can give you a reference-you should always wet the block, CMU, before the scratch coat, except in cold weather. The idea of wetting the block is to slow down the suction, or the rate the block absorbs water. On a high suction surface, like blocks, the idea is the mortar is absorbed into the pores and not the water absorbed out of the mortar. Of course this will provide a better bond and a stronger product. It is a good idea to knock the dust off the block anyway. There is no advantage to wetting the block in cold temperatures, say less than 40 degrees. The cold temperature slows down the water absorption, and helps set the mortar up faster. It may be a common practice in Florida not to wet the block first when they put three coats on the block the same day. I don't know so I can't say this first hand. I can see when more wet mortar is put on immediately it would control the suction. I don't know. Maybe someone from Florida can write to clarify this. |
